  2. Just a reminder that you MUST provide contact details if you post a For Sale or Wanted notice. The reason is that non members have access to read your advert, but can't post, so if you don't provide details, they can't contact you to buy or sell.
    Dismiss Notice
10 L Two Part Epoxy Primer
Discussion in 'General For Sale / Wanted' started by Mike Neave, 2/1/17.
  1. Mike Neave
    Mike Neave Mike Neave Solent Branch Committee General Committee
    61
    GANNET
    Wicor Marine (Portsmouth)
    Moody 35
    Solent & South Coast
    10 L Jotun Penguard HB two part Epoxy Primer + Low Temperature additive + 5 L Thinners
    Surplus to requirements, Ideal as a below waterline epoxy coating
    A high build, two-pack pure epoxy primer.
    Can be used above and below the waterline.
    Excellent adhesion to GRP and should be used when painting over the gelcoat for the first time.
    Extremely water resistant and will help prevent osmosis.
    Excellent adhesion to steel, aluminium, bronze, wood (marine ply) and galvanised steel.
    Adheres well to concrete and makes an excellent swimming pool paint when correctly applied directly on a rendered surface.
    Can also be used in tanks for potable water (drinking water) providing the correct guidelines are followed.
    Winter Note: Use Jotun Penguard Low Temperature Additive to enable curing at temperatures below 10C
    Unused and unopened purchased in October for Project that is not going ahead
    £70 Collect only from Fareham area (Due to weight) or could deliver to Portsmouth/Southampton area
    Contact mikeneave@mneave.co.uk or PM
