  2. Just a reminder that you MUST provide contact details if you post a For Sale or Wanted notice. The reason is that non members have access to read your advert, but can't post, so if you don't provide details, they can't contact you to buy or sell.
    Dismiss Notice
Moody 419 Just Testing The Water: Moody 419,1985,sell Or Part/ex For Smaller Boat.
Discussion in 'Boats For Sale / Wanted' started by Mark Todd, 12/1/18 at 09:48.
  1. Mark Todd
    Mark Todd Mark Todd
    49
    BALOO
    RNYC,Blyth
    Moody 419
    UK
    hi, just testing the water............
    we have a lovely moody 419,Baloo,an absolutely lovely boat, with a full intensive current survey in hand, which gave her a glowing report.
    she has had a new mast, both standing and running rigging replaced in 2014,and new mainsail late last year. She sails absolutely lovely.........and is very fast and smooth.
    due to my wife's ill health, and also the fact my wife and I find her a challenge berthing in our close pontoons, so we are maybe thinking of going back to a 36'ish sail boat instead.
    something like a moody 36 would be ok. (may even consider other makes)
    is anyone interested in upgrading to a larger boat, or even buying outright?
    price wise around the £55,000? (in part ex) or massive discount for a serious cash purchaser.
    1985 Moody 419
    Price: £55,000
    Tax Status: Tax Paid
    Advertiser: Mark Todd
    Telephone: 07949 018018
    Description
    Equipped for Blue Water sailing, Baloo had been continually upgraded by professional owner during the last ten years. Full survey 2014 - 'She is a nice example of her class. She has clearly been well maintained'. All recommendations completed.
    Specifications
    Vessel type: Bermudan rigged sailing yacht
    Designer: Bill Dixon
    Builder: Moody
    Make: Moody
    Model: 419
    Year constructed: 1985
    Sail number: 1205L
    Registration: SSR127024
    Berths: 8
    No. of engines: 1
    Engine model: Thorneycroft
    Engine power: 50
    Fuel type: Diesel
    Drive type: Shaft drive
    Length over all: 12.7m
    Beam: 4m
    Maximum draft: 1.8m
    Hull material: Glass Fibre
    Hull colour: White
    Keel type: Fin Keel
    Fuel capacity: 50 Gallons
    Water capacity: 100 Gallons
    Engine(s)
    Thorneycroft T108 50hp. Regularly serviced and maintained.
    New prop shaft and cutlass bearing,Kiwi 3 blade folding prop,Ambassador rope cutter all fitted in 2014.
    Electrical Systems:
    Three 12 volt AGM domestic batteries
    One 12 volt starter battery
    Alternator charging
    Sterling battery management system
    Clipper battery monitor
    Calorifier for hot water from engine
    Immersion heater
    Inverter
    120amp solar panels mounted on goal posts aft
    Rutland wind generator.
    LG 42" smart tv.
    Construction
    Built in 1985 by Marine Projects for Moody Yachts to a design by Bill Dixon.
    Accommodation
    The layout provides up to eight berths with the three double sleeping cabins separate from the main saloon.
    All new curtains throughout and matching cushions.
    In the fore cabin is a V berth with infill and stowage under. Opening hatch to the deck. Separate heads to starboard with marine toilet, shower and washbasin. Double cabin opposite with two single berths. In saloon, two settee berths.Opening hatch to deck. Saloon table with drop leaves. Chart table to starboard with galley opposite. LG 42" smart tv on wall.Waeco fridge and Nelson Tecma two burner gimballed gas cooker with separate grill and oven.
    Hot and cold pressurised water to twin s/s sinks. 100 gallons fresh water capacity. Walk through to aft cabin with excellent access to engine room. Aft cabin with large double berth. Hanging locker and dressing table. Opening hatch to deck. En-suite heads compartment with marine toilet, shower and washbasin.
    Equipment
    Deck equipment:
    45lb Kobra anchor with chain
    Aluminium kedge anchor with warp
    Electric anchor windlass
    Granny bars at mast
    Spray hood.
    Cockpit table with glass holder
    Stainless steel boarding ladder
    Various warps and fenders
    Sails & Spars
    Masthead rigged sloop. Anodised aluminium mast (2014) and boom.
    Stainless steel standing rigging (2014) . Detachable inner forestay. Running rigging renewed 2014. Slab reefing mainsail. Stack pack.
    Profurl headsail system. Three halyard winches and one reefing winch on mast. Two 48 self tailing primary sheet winches. Furling winch. Main sheet winch. Spinnaker pole.
    Mainsail - new 2017
    Furling Genoa - 2012 with light use
    Hank on storm jib
    Spinnaker - with snuffer
    Navigation Equipment
    Plastimo steering compass on pedestal.
    Clipper instruments - boat speed and depth, wind speed and direction. GPS repeater.
    Standard Horizon 300 plotter.
    Standard Horizon GX2000 VHF
    Garmin 152 GPS
    Icom 710 SSB long range radio (this may be removed prior to sale unless specifically needed)
    Windex and VHF combined aerial
    Masthead and deck level navigation lights
    Safety Equipment
    Ocean Safety 4 Man canister Liferaft (New 2014)
    Two horseshoe life buoys
    Radar reflector
    Manual bilge pump
    Electric automatic bilge pump
    Fire extinguishers and fire blanket
