Wanted Moody 30 spinnaker specifications
Marcus Browne
Marcus Browne
MINSTREL
Portland
Moody 30
Channel Coast
Does any M30 owner have the spinnaker specifications? Mine had one originally, but sometime during the 7 or so changes in ownership, it's disappeared.
Hi Marcus,
Unfortunately, the Moody Archive gives sail areas for the Moody 30, rather than the usual rig dimensions (I,J,P,E) so it's not easy to work out sail dimensions. However, I would expect any decent sailmaker to have easy access to the dimensions of a full size spinnaker for a production yacht so just ask your friendly local sailmaker.
Minstrel seems to have wandered a little from her home port.
Marcus Browne
Marcus Browne
MINSTREL
Portland
Moody 30
Channel Coast
Thanks for that. Given it was standard issue at the time, I'm a little surprised it was wasn't included in the base data, but there we go. I have purchased a spinnaker at a jumble, but just wondered what is 'should ' look like!
Yes, had her shipped to Portland Marina last year. The previous owner had fallen ill and She had not been in the water for a several years. Nice to keep these lovely Boats going.
David Rymer
David Rymer
CARIAD
Mylor
South West
Hi Marcus,
Is it a spinnaker or cruising chute you require? I'm afraid I have neither to part with, but when we had an M30 the cruising chute was I felt rather generous, so when we changed to a M346 I kept the chute and it's a good fit. However if you hoist the chute close to the top of the mast the tack should be close to the bow roller. I lead the tack line back to the cockpit as its the best way to dump the sail if things start to go wrong and by adjusting the tack line you can control where the sail flys.
