Moody 36 (80s) Moody 36 cc
  • Thread starter Juan Del Rey
J
Juan Del Rey
Thinking in a 1980 Moody 36 cc. Is she suitable for solo sailing ? The model I have seen has a main furled in the boom. Somebody knows this sytem ?
Thanks in advance.
C
Chris Burn
Sailing it would be easy enough, with auto helm, mooring it could prove to be a challenge depending on conditions, mooring is in my opinion the tricky bit, single handing takes much planning. Anchoring easy, picking up a buoy trickier but ok, tight marina berthing ........ well, if you radio ahead and threaten to crash into lots of things they will send some one to catch a line, ..... lots of fenders would be good.
Shouldn't be trickier than any similar yacht.
Good luck.
Duncan Hall
Duncan Hall
GOOSE
Mayflower, Plymouth
I often single hand a Moody 42 which is similar. Most marinas send someone to catch lines which is only a problem when there are cross currents. In mast furling is fine once you get the boom height right.
Duncan
J
Juan Del Rey
This model has a bow thrust, I think this can help in doking.
Ian Henderson
Ian Henderson
Thanks in advance.
You will find this yacht a real challenge in any marina if there is a cross wind especially single handed, The steering position is not convenient for single handed berthing. I suggest you look for an aft cockpit boat where single handed berthing is possible.
J
Juan Del Rey
Thanks to everyone for your answers.
Juan
Hi Juan,
I don't think you will find her any more challenging than any other 36 footer and I don't find centre cockpit boats any more difficult to berth single handed than aft cockpit - in both cases single handed makes little difference until you reach the point where you have to let go of the helm to lassoo a cleat.
The in boom furling is not a standard feature, so you need to specify the brand for anyone to offer a useful opinion on it.
