Moody 47
Garth MacLean
Garth MacLean
HI
Looking at a mid 2000's Moody 47.
Do all Moody yachts have a cast iron keel and steel keelbolts?
Are the teak decks and cockpits full thickness hardwood or are they laminate?
Thanks in advance for your info.
Stuart Wineberg
Stuart Wineberg
MOODY BLUE
Ocean Village
Channel Coast
I’m sure an owner of this model will come along but generally, to Q1 yes
Teak decks are timber, cockpits are laminated and deteriorate and have often been replaced and upgraded
Michael Barrett
Michael Barrett
WHITE STAR
Fishing Bay Harbor Marina
Moody 46
Chesapeake Bay, Usa
I have a M46, year 2000. Had a 38CC, year 2002. Both have iron keels and mild steel keel bolts. There is a lot of traffic in the tech library about surveyors disliking rusted mild steel keel bolts. Somewhere in the tech library literature I read the reason why Moody chose mild steel. It was a logical one, and in 99.9% of the accounts, when a bolt was pulled, the rust was limited to the locking nut and bit of exposed bolt emerging from the nut. A non-issue.
My decking is sold teak. The outer edges were both glued down and held with screws. One can see the plugs. All the inner planks were glued down. No leaks, and the two or three other M46 owners I know have not had issues.
Cockpit seats are laminated and the lamination fails after ten years or so near the curve at the stern owing to water pooling by the drain holes on both sides. The drain holes are too high. Chipped out my seats and replaced them with solid 8mm strips. No issues but the drain holes are still too high. No real solution. I have a bimini so it is not too much of a problem.
Michael Barrett
Garth MacLean
Garth MacLean
Michael Barrett
Thanks for your reply. My concern would obviously be the screws on a balsa cored deck.
Cheers
Michael Barrett
Michael Barrett
WHITE STAR
Moody 46
Chesapeake Bay, Usa
Mr. MacLean,
As far as I know, Moody sailboats have cored decks except for areas where backing plate support is needed. Then it is solid plywood. The M46 and M47 have cored decks and indeed hulls above the waterline are cored as well. Nonetheless, this has not posed any leakage issues on my vessel where the teak is screwed down--the outer border or frame, one plank wide. In-between was all glued.
The sole in the cockpit is teak laminate like the cockpit seats. I have replaced my seats (as have many Moody owners) with solid teak. This spring I intend to sand down the sole laminate and seal with with the stuff I use on my seats and cap rails. I have had no water issues with the sole but it is simply dirty and scruffy after all these years. A light sanding should not penetrate the laminate.
Best,
M.B. Barrett
