  2. Just a reminder that you MUST provide contact details if you post a For Sale or Wanted notice. The reason is that non members have access to read your advert, but can't post, so if you don't provide details, they can't contact you to buy or sell.
    Dismiss Notice
Wanted Prop Puller (borrow)
Discussion in 'General For Sale / Wanted' started by Mike Neave, 1/11/16.
  1. Mike Neave
    Mike Neave Mike Neave
    45
    GANNET
    Moody 35
    Solent & South Coast
    Has anyone got a prop puller I could borrow ?
    Need to remove the prop over winter and it's being stubborn
    Happy to collect and return from Solent area (Portsmouth/Southampton etc) and would provide beer money
    TIA
    MIke Neave
  2. Pete Rowland
    Pete Rowland Peter Rowland
    954
    APRIL LASS
  3. Mike Neave
    45
    GANNET
    Moody 35
    Pete
    Thanks, will give you a call Friday when I am back in country to discuss
    Rgds Mike
  4. Pete Rowland
    954
    APRIL LASS
  5. Mike Neave
    45
    GANNET
    Moody 35
    Well spotted
    I have Pm them as that's a bargain
    If if does not work out I will be back in touch
    Rgds
    mike
  6. David Longhurst
    David Longhurst David Longhurst
    1,099
    STOLEN MOMENTS
    Mike
    Here is how I get the prop off my M346.
    I use the largest of the 3 leg gear pullers in the Machine Mart set - see https://www.machinemart.co.uk/p/cht270-3-pce-gear-puller-set/
    Und the nut at the end of the prop shaft, but do not take it off - I undo mine until its just starting to come off the shaft - this provides a small recess to fit the centre of the gear puller.
    Put on gear puller and tighten up as much as you can - its quite likely, as the prop is on a locking taper, that it still wont budge.
    Apply gentle heat to the prop hub - I use a blowlamp, but a paint stripping gun might do. I also wrap the P bracket and prop shaft in a wet towel to keep it cool and to protect the cutlass bearing.
    There is quite a lot of thermal inertia in the prop, so it takes a few minutes to warm up. I find that after a few minutes of heat from the blowlamp you hear a gentle 'ping' as the expansion of the prop breaks the taper and the pressure from the gear puller pulls it back against the nut. Its likely that as the prop releases the gear puller will fall off.
    Let it cool a bit, take off nut on end of shaft and remove prop - and catch the key which is set into the shaft to stop the prop from rotating as the prop comes off.
    Hope this is helpful
  7. Mike Neave
    45
    GANNET
    Moody 35
    Pete
    Now the owner of a Heavy Duty Puller which should do the Job Nicely, Thanks for the tip off
    David yes that's how I have had it off before I also find that after Warming it up with a heat gun a Kettle of Boiling Water helps
    Rgds Mike
