Wanted S336 Raymarine Analogue cable
Jon Bell
Jon Bell
Solent Branch Committee
TIGERMOON II
Gosport
Moody S336
South of England
Hi all,
I seem to have an intermittent fault on my Pathfinder Raymarine Radar. I have purchased a second hand scanner, but was wondering if anyone had an old cable kicking about? I have tried to find one on flea bay, but no success. Any help appreciated. Alternatively, if someone can tell me how to test the scanner without climbing the mast and using the current cable, I would be most grateful.
Here's hoping.
Jon
Martin Johnson
Martin Johnson
JUBILANT
Southsea
Moody S38
Hi
You've not mentioned which display you're using but these links might help...
http://forum.raymarine.com/printthread.php?tid=1510
And a second test here..
http://raymarine.ning.com/m/discussion?id=6492755:Topic:5690
As to faults... Some of these radomes are sadly getting on a bit now and I've kept a few going a few more years by replacing various degraded capacitors within the radome... If it's a rotation timing error then it might just be a faulty sensor which is also easily replaceable..
Diagnostic menu should clarify if it's the radome at fault.
Jon Bell
Jon Bell
TIGERMOON II
Gosport
Moody S336
South of England
Tks Martin, have PM'd you.
Jon
Jon Bell
Jon Bell
TIGERMOON II
Gosport
Moody S336
South of England
Still looking for an old analogue cable - happy to borrow if someone is kind enough to lend me one. Also happy to accept faulty cable as it is only being used for a test, so I can repair it if needs be.
Tks
Grenville Hancock
Grenville Hancock
VENTURIA
Vannes, Morbihan
Moody 35
West France
I am in the process of removing a functioning Raymarine / Autohelm greyscale SL72 radar.
At the moment, I have a the Radome with approx. 8m of cable at home and the display unit. However the reminder of the antenna cable, including the socket at the display end and the power cable/connector is still installed on the boat and won't be coming home until the beginning of April.
Jon Bell
Jon Bell
TIGERMOON II
Gosport
Moody S336
South of England
#6
Tks Grenville,
Have PM'd you.
Jon
