Spinnaker pole for sale
Bryan Coote
Bryan Coote
CEOL NA MARA
Ashlett SC, Ashlett Creek, Southampton Water
Moody S31
South Coast & Channel Islands
I have a spinnaker pole for sale.
It’s approx. 10ft 10inches long and 2.5/3nches diameter. The end fittings (Which are the same each end and are sprung jaws with a trip line) are attached with three rivets so would be easy to drill out to enable the pole to be shortened. There are small pins either end with holes top and bottom to take an uphaul and downhaul.
Any questions please ask.
Looking for £40 but open to sensible offers.
Buyer to collect.
Barry Voysey
Barry Voysey
LIONA
Pwllhelli
Do you know what it was off originally
John Hawthorne
John Hawthorne
BUNNY BEE
Fehmarn
Moody 38
Baltic
I am interested, I just need to check my length needed, where abouts is it and can you clarify the diameter
Bryan Coote
Bryan Coote
CEOL NA MARA
Moody S31
Hi John,
It’s in Chandlers ford near Southampton. Diameter is 3 inches. In terms of length, it would be easy to shorten if required. Hope this helps.
Bryan.
Bryan Coote
Bryan Coote
CEOL NA MARA
Moody S31
Hi Barry.
The pole originally came off a Westerly Griffon but we believe it was too big for that boat - probably more suited to an approx. 30 footer. Any other questions please feel free to ask.
Bryan.
#6
Hi,
A spinnaker pole should be J in length, any less and it won't get the tack of the kite ahead of the forestay when reaching. Looking at the Moody archive, J for a Moody 31 is 12' 5". The diameter at 3" is alarmingly small for a spi pole on a 30 footer - you can work out what dia is required for any boat with the Selden caralogue. They say you can get away with smaller diameter for a whisker pole, but recommend length greater than J for this purpose.
I haven't checked what J is for a Griffon, but suspect 10' 10" may be about right, Again 3" diameter sounds a bit small, but may be OK if the wall thickness is greater than usual. The combination of tube diameter and wall thickness is to prevent the spar from buckling when loaded in compression. If you've ever done the foredeck job with a kite, you'll know that the compressive load can be high.
p.s. I just checked the Griffon rig sizes and J is a gnats over 10' 9" according to Sailrite, so that pole would have suited a Griffon. Looks like a 72mm diameter x 2,2mm wall thickness would serve. P.
John Hawthorne
John Hawthorne
BUNNY BEE
Fehmarn
Moody 38
Baltic
#7
Hi John,
Bryan.
Hi Bryan I am interested, I’ve just got to check the size but as you say it might be easy to shorten it, I want it as a Genoa pole not a spinnaker pole, I will get back with a decision in the next 2 days if you can hold it for me
Regards John
John Hawthorne
John Hawthorne
BUNNY BEE
Fehmarn
Moody 38
Baltic
#8
Hi Bryan
Sorry I needed it a bit longer, good luck with selling it
#9
Hi John,
Selden recommend a whisker pole should be as long as the foot of the sail to be poled out which, for most genoas, is greater than J. Having said that, most folk get along using a standard spi pole, which is J long. Depending which Moody 38 you have, your J is 14' 10" (circa 1990s) or 13' 4" (circa 2000). On the earlier M38, a 10'10" pole will protrude about 4' 6" from the rail (beam 12' 8") and on the later one about 2" more (beam 12' 4").
John Hawthorne
John Hawthorne
BUNNY BEE
Fehmarn
Moody 38
Baltic
#10
Hi Peter
Thanks,we ave an extendible ski pole but it’s quite heavy so I thought a 3 in pole for use in light winds would be useful, but as you have explained we need one about 13 feet
Thanks John
#11
Hi John,
Good one! We were making good use of ski poles today, but not telescopic and rather less than 3" diameter. ;)
