Wanted wanted M31 2 bladed fixed prop
Ian Coward
Ian Coward
NIKITA
Tollesbury
Due to some severe galvanic corrosion I need to replace my 2 bladed fixed prop (and also prop shaft..!) on my Moody 31 with a new one.
If any one has replaced theirs with a folding prop and still has the old one in the shed I would be interested.
Martin Courtis
Martin Courtis
TUI
Anywhere
UK, West Coast France
What size is your prop and shaft. I have one that came off a 376. May be too large for you but??? You never know.
Martin
Simon Hale
Simon Hale
BARLEY WINE
Fleetlands, Portsmouth
Moody 30
Hi Ian. I have a 3 blade prop from a Volvo SD120 saildrive on a Moody 30. It was too just big for my Moody 30 so may be just what you are after!
Ian Coward
Ian Coward
NIKITA
Tollesbury
Martin
Thanks Martin
Think it maybe too big , but as my prop has been badly corroded I cannt really tell the dimensions
Hi ian,
A good rule of thumb for sailing yachts is to go for a clearance of at least 10% of prop diameter between the blade tip and the bottom of the hull. So, assuming you have your boat ashore, measure the distance from the centre of the shaft to the bottom of the hull in a direction perpendicular to the shaft at the position of the prop. Multiply the result by 1.67 and that's the largest diameter I would install. Although a larger diameter prop will fit, you risk getting a lot more prop noise and certainly reduced prop efficiency.
Once you know what diameter you want, It's best to trust the prop supplier to choose the pitch for which you will need to supply the boat model, the max engine power and rpm at which it is delivered and the gearbox ahead ratio. At least that way, if the pitch turns out wrong, it's the suppliers job to put it right, although prop manufacturers are generally pretty good at this black art.
Clive Bridges
Clive Bridges
HONEY B
Killyleagh
Moody 33 MkII
Strangford Lough
have a 11x9 two blade prop l/h 1" shaft came off m33 £20 plus postage
Brian Robertson
Brian Robertson
TIDECATCHER
Granton, Edinburgh
Scotland East Coast
Ian,
I am in the process of replacing my VP2003 engine in my M31 with a Beta30 (the engine is on e-bay now) and I am also going to have to replace my propeller (change of rotation). I therefore have a two bladed prop available. I took it off the boat last weekend and I now have it at home and it looks to me to be in good condition.
Get back in touch if you are interested. Mob: 07340 208528,
best regards,
Brian
Ian Coward
Ian Coward
NIKITA
Tollesbury
Ian,
best regards,
Brian
Thanks Brian interested in the prop - thanks will give you a call
Ian
Ian Coward
Ian Coward
NIKITA
Tollesbury
Hi ian,
Hi ian,
Thanks for that info Peter -really useful ..will have a measure this weekend
Brian Robertson
Brian Robertson
TIDECATCHER
Granton, Edinburgh
Scotland East Coast
Hi Ian,
Did you manage to get your prop. problem sorted out? My new (right handed) prop arrived the other day (lovely and shiny !!) and is ready for installation with my new Beta engine. It seems a shame to have to cover it in anti-foul !
If you are still looking for a replacement prop. for your own boat then mine is now excess to requirements and is available for any reasonable offer,
best regards,
Brian
Ian Coward
Ian Coward
NIKITA
Tollesbury
Hi Ian,
best regards,
Brian
Hi Brian
Just waiting to hear from Insurers to see if they will cover the claim
Should hear by end of this week.
Ian
