For Sale Keel stud backing plates
BLUEBELL
Plymouth
Moody 44 (90s)
UK West Coast and Channel
Recently I had keel stud backing plates laser cut for our Moody 44.
The order was subject to a minimum charge. Rather than pay for nothing, I increased the quantity and have the remainder for sale.
The backing plate profiles are cut from 10mm mild steel. The laser cutting process is 2D only, so some grinding is required to bevel the edges.
I have;
30 off 75 x 75 x 10mm with 27mm holes. Suitable for M24 studs.
5 off 50mm OD with 15mm holes. Suitable for M12 studs.
75 x 75mm £1.50 each
50mm £1.00 each
Our M44 has 15 off M24 + 1 off M12 studs. The cost for a set is £23.50 + £6 Royal Mail to Mainland UK.
07812714126
  • Backing plate for 12mm Rev 2 6Mar2023.pdf
  • Backing plate for 24mm Rev 2 6Mar2023.pdf
Hi Andrew, thanks for letting us know.
I have a few of these left.
10 off 75mm x 75mm
3 off 50mmOD
John, I will take the 75x75mm plates. PM on its way.
Regards Pete
3 off 50mm OD remaining.
