- TINY DANCER
- TBA
- Moody 425
- Mediterranean
Hi
For sale 2 x New AMPS 12V 300Ah LiFePO4 - Lithium Iron Phosphate Battery w/ Bluetooth.
£650.00 each + delivery (I would recommend collection as they are heavy)
300A JBD - BMS This 300Ah battery is in a newer, more compact battery case.
| Battery power | Weight of battery (kg) | Dimension of battery (cm) |
| 12V 300Ah | 29 | 47.0L x 19.0W x 24H |
- LiFePO4 12V (nominal) 300Ah 25 deg C Lithium Deep cycle
- Maximum continuous charge rate = 310A
- Maximum continuous discharge rate = 310A
- Battery must be safely charged within units parameters
- Max charge V=14.6V, Recommended =14.4V, Float V=13.8V
- Cut off voltage 11V / cutoff temperature 60 deg C
- Charge Curve style CC/CV
- Operational temperature 0Deg to 60 deg C (adjustable)
- internal consumption: Operational = 10mA, Dormant 0.1mA
- 8mm ring terminal battery studs / washer
- Can be put in series 12V | 24V | 36V | 48V
- 0 Deg C charge circuit disconnect
- -20Deg C discharge circuit disconnect
- 100W heater built in for sub-zero charging.
