Wanted Fuel Filter Cover
Luca Colombi
CALIDRIS
Gosport
Hi everyone,
I'm on the lookout for a fuel filter cover for a Volvo Penta 2003.
If anyone happens to have a spare one lying around or knows where I might find one, I’d really appreciate it if you could get in touch via email luca.colombi@gmail.com
Thanks so much in advance!
Best regards,
Luca
Hello Luca,
You would have made it easier if you taken a picture of the part number.
I know Its difficult, but using the correct title of the part helps.
This is the fuel filter head or some call it the fuel filter assembly.
It's not a cover.
With some digging around, I've found our the part number is 840532.
Searching for a Volvo Penta 840532 suddenly gives you a whole lot more options.
Seems like the only one on the planet at the moment is here:-
Fuel filter head for series 2000 Volvo Penta 840532 (https://www.shipoutletstore.com/en/fuel-filter-head-for-series-2000-volvo-penta-84053.html)
Hope that helps,
Hi David,
Thanks for your help and the link, I've found something that might do the job.
It's not the exhactly the same but I was told it will work fine with the extra ports blocked. I've purchased the part and waiting for it to arrive.
Please note, I was in the garage when I took the photo, wasn't sure about the name and used the VP diagram as reference (attached) it said Cover so used that. I should have included the part num too. Lesson learned.
Many thanks,
Luca
No problem, just pleased you're sorted now, and at a sensible price.
Sorry if I was a little harsh about the terminology, but searching for a filter cover was going nowhere.
