- PONDLIFE
- Hamble
- Moody 42
- Solent /Brittany
Pondi is a year 2000 model. She will be going on the market in a month or so. I thought I’d put a post on here in case anyone would like to ask questions or arrange a viewing beforehand. The boat has been maintained and updated meticulously:
Saloon upholstery refitted in leather by Moody’s original supplier/fitters
Forward cabin, aft cabin and pilot berth cushions and foam replaced in 2017
Rigging changed in 2017
New Eberspacher 6kw heater fitted this year
Original veneered cockpit seats, sole and transom step replaced in solid 9mm teak by Moody Decking
New sails fitted in 2017 and very lightly used for 6 months each year
Hull epoxied and Coppercoated in 2007 and re Coppercoated in 2017
Below waterline seacocks changed 2017
Main Saloon table reveneered due to natural
wear and fade
Brand new 60m 10mm anchor chain with Manson Supreme 20KG anchor
New hatch lenses replaced a couple of years ago and fixed opening windows replaced in 2017
Raymarine radar and chartplotter fitted in 2017
Very high end sound system fitted this year
Three brand new AGM batteries (429amps)
Keel bolts changed last year
New carpets fitted throughout this year
Silent Wind generator fitted 2017
New 120w solar panel
Windscreen frame stripped and repowdercoated in 2017
New suede wheel cover
Fridge keel cooler, evaporator and thermostat replaced recently
Spray hood plastic renewed recently
New led concealed lighting throughout
Front and back heads pipes recently replaced with access panel added in main heads to facilitate future removal
Autopilot serviced and new belt and gears last season
Bootline stripped and repainted with four coats of two part undercoat and topcoat (International Perfection) this year
Exhaust elbow and connector changed recently
New instrument panel and hour meter
Throttle gear mechanism and control cables renewed this year
Boat fitted with:
50 amp battery charger and 1.5kw inverter
Navtex
Teak cockpit table
Icom VHF with AIS receiver and cockpit comand Mike
Cabin lock security bar
Full cockpit cover
Opening aft cabin rear window and four opening galley/chart table windows
Link 10 battery monitor
Sterling alternator booster
Transom shower
Liferaft
Stainless bow protector
Old set of Hood winter sails
The boat is in superb condition. A surveyor took a couple of readings when she was ashore this year and found it to be very dry. Boat is in Hamble. Here are a few pics. Tel no. 07578305588
wear and fade
Boat fitted with:
Navtex
Teak cockpit table
Full cockpit cover
Transom shower
Liferaft
