For Sale Sniper 19 (actually 18 inch screen) Travel TV
Colin Shead
Colin Shead
Moderator
This little TV works perfectly, and has a 12 volt mains adapter as well as a cigar type plug for 12 volts. It only draws about 1 amp on 12 volts.
It has a full international TV tuner with both conventional and satellite inputs, for analogue and digital TV.
A DVD player is built in.
It has HDMI and other inputs for a PC etc, but it is not a smart TV.
The sound is rather tinny as to be expected from a small TV. It has bluetooth built in for headphones or small sound bar if you prefer.
On 'Toodle Pip' I used it with an omni directional travel antenna which included an antenna amplifier.
Probably best collected (CM8 3PQ), or can post at additional cost.
£40 or make me an offer.
All the best Colin Shead
(cjshead01@gmx.co.uk or 07956 782298)
Hi Colin, Has this TV now gone? if not what size is it? and where are you located? cheers Lucy
sorry missed it says 18 inch. Has it gone/?
Hi Lucy,
Tv is still available. We are located in Rivenhall Essex CM8 3PQ. I could post it via a courier but probably best to collect and have a demonstration if you would like.
All the best Colin
Hi Colin, did it sell ? Might work perfectly for an old boat i recently bought if still available
Very sadly Colin's TV/DVD is too big for the space I have for it. Just to add his very helpful info, here it is. Hope it helps someone
Stand is removable, and there are VESA fixings on the back for a wall mounting.
There is a recess on the back for the main connections, antenna, HDMI, power etc. Other connections for USB etc are on the side, again recessed from the screen edge.
The DVD drive, if you want to use it, has a slot on the screen edge.
The overall dimensions, without the stand, are 440mm wide, 263mm high, and 52 mm dee
